[GRASSGUI] Re: python question - waiting for a variable to change
Daniel Calvelo
dca.gis at gmail.com
Mon Mar 19 12:24:09 EDT 2007
You could make your callback function (the one you wish executed as
the value is returned) a parameter to __init__ in menuform, that is
called from within menuform.onRun if set to stg else than None. I
think that is what you call a hook.
You have to build something quite involved to have signaling objects
behave like normal variables, AFAICT.
Daniel.
On 3/19/07, Michael Barton <michael.barton at asu.edu> wrote:
> I've run into a little problem that is taxing my neophyte Python
> programming abilities. However we do a popup panel for setting display layer
> options, I think it is necessary to do something along the lines of the
> following....
> 1. Start the options popup. This is currently done with a double click on
> the layer, which calls the onActivate even handler. For a raster, the event
> handler uses...
> drastcmd = menuform.GUI().parseCommand('d.rast', gmpath)
> ...to start the autogenerated GUI.
> 2. When you press the "run" button for this d.* command, the assembled
> command (d.rast + options) is simply returned.
> 3. Now drastcmd should contain a complete d.rast command string.
> So, how do I wait in onActivate until the "run" button is pressed on the
> popup and the information is returned to drastcmd (i.e., the value of
> drastcmd is changed). Or, alternatively, how can a change in the value of
> drastcmd generate an event that I can capture and process? I messed around
> with wait() (thinking about tk_wait in TclTk), but couldn't get it to do
> what I wanted.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
-- Daniel Calvelo Aros
More information about the grass-gui
