[GRASSGUI] Re: [GRASS-dev] Python GUI issues
Daniel Calvelo
dca.gis at gmail.com
Mon Mar 19 12:37:31 EDT 2007
On 3/17/07, Glynn Clements <glynn at gclements.plus.com> wrote:
> It seems to work (although the source path is hardcoded in the
> fix-icon-paths.pl script, so it won't work if anyone else edits the
> file).
Yep, there is a comment on the script source, so people must be
careful with it. That's also why it doesn't replace the original file
or create a backup: if you must use it, be careful.
> The fixed copy should be stored in SVN, so we'll probably need another
> script to convert them back to absolute paths for editing in Glade.
At some point, I hope wxGlade will have served its purpose and the
code will start been tweaked by hand.
Daniel.
-- Daniel Calvelo Aros
More information about the grass-gui
