[GRASSGUI] Re: [GRASS-dev] wxgrass prototype
Moritz Lennert
mlennert at club.worldonline.be
Wed Mar 21 10:39:16 EDT 2007
And a few more remarks:
- When double-clicking on an already existing layer to make the
d.vect/d.rast window appear, this window does not contain the map name
of the map that was selected before. I think this should be the case, as
when you just want to modify one option, you don't want to always have
to reselect the map name
- Flags (such as d.vect -c) do not seem to be taken into account (at
least they don't show in the command line displayed in the output window).
- When using the provided Init.sh to run grass -wx, wxgrass is modal,
i.e. you don't have access to the command line in the terminal window
anymore.
Moritz
More information about the grass-gui
