[GRASSGUI] changing data for parser
Thu Mar 22 10:08:28 EDT 2007
Michael Barton wrote:
> menuform.py uses the xml text generated by "<command>
> interface-description" to create the autogenerated dialogs. This dates to
> 2001.
> I was just reminded in a recent post to the grass developer list that there
> is a richer interface description output called by "<command> --tcltk".
AFAICT, --interface-description is simply missing the ->guisection
field. There's no reason why that field cannot be added.
I don't see any point in using the --tcltk output for Python code.
More information about the grass-gui mailing list
