[GRASSGUI] initiating d.* command dialogs with existing parameters
Sun Mar 25 12:41:01 EDT 2007
Michael Barton wrote:
> I can't remember the exact error, but it said essentially that "PIPE" is not
> a valid parameter. This could be a bug in the Mac version, of course. But it
> would be nice to see if it works on another platform before I report it, in
> case I've just forgotten some punctuation, capitalization, or something.
You either need to use subprocess.PIPE, or change "import subprocess"
to "from subprocess import *". If you take the latter approach, you
need to remove the "subprocess." prefix from subprocess.call,
subprocess.Popen etc.
The "import <module>" syntax requires you to use qualified names,
while "from <module> import *" allows you to use unqualified names.
Alternatively, you can import specific identifiers, e.g.:
	from subprocess import (call, Popen, PIPE, STDOUT)
In any case, the call:
            self.out = Popen(cmd, shell=True, stdout=PIPE, stderr=STDOUT).communicate()[0]
seems to work once the relevant identifiers have been imported.
BTW, GMConsole.runCmd() currently executes the command twice; once
with call(), and again with os.popen().
Also, I had to remove an "import images" statement from wxgui.py; that
module doesn't appear to exist.
More information about the grass-gui mailing list
