[GRASSGUI] something squirrelly with the PNG/PPM driver
Glynn Clements
glynn at gclements.plus.com
Tue May 8 11:56:36 EDT 2007
Michael Barton wrote:
> Here are all the standard settings from the TclTk and wxPython GUI (from
> TclTk syntax here)
> set env(GRASS_WIDTH) "$driver_w($mon)"
> set env(GRASS_HEIGHT) "$driver_h($mon)"
> set env(GRASS_PNGFILE) "$mapfile($mon)"
> set env(GRASS_BACKGROUNDCOLOR) "ffffff"
> set env(GRASS_TRANSPARENT) "TRUE"
> set env(GRASS_PNG_AUTO_WRITE) "TRUE"
> set env(GRASS_TRUECOLOR) "TRUE"
> set env(GRASS_RENDER_IMMEDIATE) "TRUE"
> Add a barscale or legend (try a legend for elevation.10m from Spearfish) to
> the GUI layer tree and render. Do you get correct colors?
The following produces the same colours as XDRIVER:
GRASS_BACKGROUNDCOLOR=ffffff \
GRASS_TRANSPARENT=TRUE \
GRASS_PNG_AUTO_WRITE=TRUE \
GRASS_TRUECOLOR=TRUE \
GRASS_RENDER_IMMEDIATE=TRUE \
GRASS_PNGFILE=map.ppm \
d.legend elevation.10m
> I had updated, did a distclean, and compiled on Friday. Colors are not
> rendering correctly, and I'm getting partial rendering in some cases. I can
> look in the tmp directory where this stuff is getting rendered and check the
> PPM (and PNG files in wxPython) and can see the colors problem in the
> graphic file.
> This is only happening when writing to the PNG (PPM) driver. Using the X
> driver gives no problem. Oddly, maps seem OK, but scalebars and legends are
> a problem. I suppose that the problem could be something that d.barscale and
> d.legend are both using, but that maps are not.
> It could be specific to my office workstation (Mac G5, OS X 4.9). If so,
> I'll update and recompile. But I want to check to see if this is happening
> to anyone else.
Not to me.
So far as any futher tests are concerned, execute any commands
manually, in order to eliminate the GUI as a source of potential
problems.
More information about the grass-gui
