[GRASSGUI] wxgrass does not see wx on import
Michael Barton michael.barton at asu.edu
Sat May 19 17:36:45 EDT 2007
It is not used, so I took it out. Committed just a few minutes ago.
Michael
On 5/19/07 10:11 AM, "Brad Douglas" <rez at touchofmadness.com> wrote:
> wxgui.py imports wx.richtext (see the error messages below).
> On Sat, 2007-05-19 at 08:50 -0700, Michael Barton wrote:
>> > I seem to remember that Jachym reported some problem with the richtext
>> > control for Windows and that we were not going to use it. Where is it being
>> > used?
>> > Michael
>> > On 5/19/07 8:37 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
>>> > > Brad Douglas wrote:
>>>>>>> > >>>>> Which widget was it? If it's part of the contrib widgets in
wx2.8,
>>>>>>> > >>>>> that's manageable.
>>>>>> > >>>> Here's the exact error:
>>>>>> > >>>> GRASS 6.3.cvs (utm10):/usr/src/grass63 > wxgrass
>>>>>> > >>>> Traceback (most recent call last):
>>>>>> > >>>>   File "/opt/gis/grass-6.3.cvs/etc/wx/wxgui.py", line 16, in ?
>>>>>> > >>>>     import wx.richtext
>>>>>> > >>>>   File
>>>>>> "/usr/lib64/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/richtext.py",
>>>>>> > >>>> line 4, in ?
>>>>>> > >>>>     import _richtext
>>>>>> > >>>> ImportError:
>>>>>> /usr/lib64/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_richtext.so:
>>>>>> > >>>> undefined symbol: wxEVT_COMMAND_RICHTEXT_CHARACTER
>>>>>> > >>>> This is what led me to believe it was a python2.5 symbol, but I'm
>>>>>> > >>>> relatively inexperienced with wxpython.  There are also no
>>>>>> unresolved
>>>>>> > >>>> libraries linked to _richtext.so.
>>>>> > >>> It should be in libwx_gtk2ud_richtext-2.8.so
>>>>>>> > >>>>> Did you try setting PYTHONPATH with a hand-compiled version of
>>>>>>> wxpython?
>>>>>> > >>>> I shouldn't have to, but I did it anyway to make sure.  No dice.
>>>>> > >>> Are the wx 2.8 libraries visible (ld.so.conf or $LD_LIBRARY_PATH)?
>>>> > >> The wx libraries reside in /usr/lib64, so I would be rather surprised
if
>>>> > >> they weren't in the LD path. :-)
>>> > > Have you run ldconfig since putting them there? Does running ldd on
>>> > > _richtext.so show their locations?
> Brad Douglas <rez touchofmadness com>                    KB8UYR/6
> Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-gui/attachments/20070519/3e55f1f2/attachment.html
More information about the grass-gui mailing list
