[GRASSGUI] GEM wizard in wxPython
Jachym Cepicky
jachym.cepicky at gmail.com
Mon May 21 15:36:40 EDT 2007
hi,
Michael Barton píše v Po 21. 05. 2007 v 11:57 -0700:
> Jachym,
> On my way to work, I was thinking that maybe we already have the tools we
> need with g.proj. We should be able to create a default WIND file, PROJINFO,
> and PROJUNITS files.
hi, not sure about this, but I was away for long time, I'll check it
jachym
> Michael
> On 5/21/07 11:54 AM, "Jachym Cepicky" <jachym.cepicky at gmail.com> wrote:
> > Hi,
> > Michael Barton píše v Po 21. 05. 2007 v 08:18 -0700:
> >> Jachym,
> >> I did a bunch of update work on the wizard awhile back, so it is almost
> >> done. Still waiting on some kind of update to g.proj or g.setproj to make
> >> the manual location creation work. I guess we could just go ahead with the
> >> epsg, georeferenced file, and related parts and ask again for an update to
> >> make the other part work.
> >> Michael
> > while ago, I had to fix some bugs to :-) Yes, he have to make g.setproj
> > more usable for our needs. I'll look at it
> > Jachym
> >> On 5/21/07 4:27 AM, "Jachym Cepicky" <jachym.cepicky at gmail.com> wrote:
> >>> Hi,
> >>> Yann píše v Po 21. 05. 2007 v 18:12 +0700:
> >>>> Hi Jachym,
> >>>> Yes, the wget+parsing is tempting, i just need to figure out how to do all
> >>>> that...
> >>>> could you tell me where i can find your New Location Wizard, maybe I'll get
> >>>> a
> >>>> hint to do that for GEM.
> >>> well,
> >>> svn co https://grasssvn.itc.it/svn/grassaddons/trunk/grassaddons addons
> >>> cd addons/gui/
> >>> $EDITOR location_wizard.py
> >>> but it is a mess - I need to clean this. try to take it really only as
> >>> an example.
> >>> Jachym
> >>>> Thanks
> >>>> Yann
> >>>> On Monday 21 May 2007 17:44, Jachym Cepicky wrote:
> >>>>> Hi,
> >>>>> basically, there are two possibilities: Use standard python packages or
> >>>>> using CLI commands. In current wxGRASS gui, commands are used, to avoid
> >>>>> new dependences. So, I would vote for some "wget+parsing" sollution.
> >>>>> For example, how to create wizard using wxpython, see wizard example in
> >>>>> wxpython demo
> (http://prdownloads.sourceforge.net/wxpython/wxPython-demo-2.8.4.0.tar.bz2>>>>>
> >>>>> I put together nearly-working new location wizard, if you will be able
> >>>>> to follow the code.
> >>>>> Jachym
> >>>>> Yann píše v Po 21. 05. 2007 v 17:26 +0700:
> >>>>>> Hi all,
> >>>>>> Anybody could "mentor" a wxPython newbie into getting a GEM Wizard up and
> >>>>>> running?
> >>>>>> Aim:
> >>>>>> 1-List some predefined Extensions
> >>>>>> 2-Select any, then download it
> >>>>>> 3-Run Gem on the .tgz file downloaded (supposed you already are in root)
> >>>>>> Thanks
> >>>>>> Yann
> >> __________________________________________
> >> Michael Barton, Professor of Anthropology
> >> School of Human Evolution & Social Change
> >> Center for Social Dynamics & Complexity
> >> Arizona State University
> >> phone: 480-965-6213
> >> fax: 480-965-7671
> >> www: http://www.public.asu.edu/~cmbarton
> phone: 480-965-6213
> fax: 480-965-7671
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
More information about the grass-gui
