[GRASS-GUI] Histogram is black/dark in GRASS when you change the
projection or co-ordinates
prashant
prashantkokate5 at gmail.com
Wed Aug 24 10:50:17 EDT 2011
I am trying hard to display the histogram in wxPython GUI. It does display
the histogram when I keep the projection undefined. But, as projection
changed to British National Grid (this is what it should be), histogram
comes out a total dark box even though image is totally perfect with true
colour in the Display window.
Near-infrared band of SPOT also has the same issue when define a projection,
but rest of two bands are perfect.
I badly need to display the histogram when I define the projection of the
images.
I would be grateful if anyone can help me out in this issue.
Thanks
Prashant
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Histogram-is-black-dark-in-GRASS-when-you-change-the-projection-or-co-ordinates-tp6720482p6720482.html
Sent from the Grass - GUI mailing list archive at Nabble.com.
More information about the grass-gui
