[GRASS-PSC] RFC: Module Option Parser
Brad Douglas
rez at touchofmadness.com
Thu Dec 14 21:59:04 EST 2006
I'm in the process of updating/upgrading the imagery libraries and
modules. I have run into a problem which I wish to simplify, but would
require modification of lib/gis/parser.c, etc.
I think we can all agree that i.ortho.photo is a mess and hasn't been
able to evolve as the rest of GRASS has. I want to remove as much
interactivity as possible, but that creates a dilemma:
A) I can break i.ortho.photo into 7-8 separate modules, or
B) I can make it a single module by using the following structure:
Option A does not set well with me and Markus has agreed, privately, due
to the ever growing list of GRASS modules, so I need something a bit
'better'.
- Create an Option that allows to select from a series of commands like
v.build does:
tool_opt = G_define_option ();
tool_opt->key = "tool";
tool_opt->type = TYPE_STRING;
tool_opt->required = YES;
tool_opt->multiple = NO;
tool_opt->description = _("The ortho tool to use:\n"
"\t\ttarget - Target imagery location and mapset\n"
"\t\tdem - Digital Elevation Model (elevation)\n"
"\t\tcamera - Camera parameters\n"
"\t\ttransform - Transformation parameters\n"
"\t\texposure - Exposure parameters\n"
"\t\tparams - Ortho photo parameters\n"
"\t\trectify - Rectify the ortho photo");
tool_opt->options =
"target,dem,camera,transform,exposure,params,rectify";
...but alter it a bit, namely changing the first line to:
tool_opt = G_define_selection(), a new function.
In order to make this work and keep the many options from spamming
i.ortho.photo --help (as many of the above selections have multiple
options that are not related to each other), I would like to propose the
following changes:
- Create a new function: G_define_selection ();
- Add another option to G_define_option () that would link an option to
a selection:
dem_opt = G_define_option ();
dem_opt->key = "dem";
dem_opt->type = TYPE_STRING;
dem_opt->required = NO;
dem_opt->multiple = NO;
dem_opt->description = _("Digital Elevation Model");
--> dem_opt->selection = "dem"; <--- new option
So...when I do 'i.ortho.photo --help', I get a list of selections to
choose from. When I do, 'i.ortho.photo select=dem --help', I only get a
list of options associated with the "dem" selection (ie. dem_opt).
Comments, suggestions, and better ideas are always welcome.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
More information about the grass-psc
