[GRASS-PSC] OpenMotif
    Brad Douglas
    rez at touchofmadness.com
    Sun Nov  5 19:27:43 EST 2006
Hello,
It has come to my attention that openmotif is not compatible with the
GRASS license.  Most of the functionality has been duplicated in
lesstif, which has a compatible license.
I've been able to successfully compile GRASS using lesstif as a drop-in
replacement.
Should we move GRASS to lesstif?  All that really needs to be done is
simply replace text that says openmotif/motif with lesstif (ie.
cosmetics).
Redhat has officially dropped support for openmotif and anything that
won't compile without it as of Fedora Core 6.  I assume other vendors
will follow.
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
More information about the grass-psc
