[GRASS-PSC] Request: CVS Write Access to Serena Pallecchi
Brad Douglas rez at touchofmadness.com
Tue Nov 28 09:28:50 EST 2006
On Tue, 2006-11-28 at 13:02 +1300, Hamish wrote:
> Brad Douglas wrote:
> > Looks good.  My only comment is to provide a physical address that is
> > associated with GRASS.  This is probably required for legality, but
> > specifically to allow copyright holders to remove themselves as stated
> > in the new documents.
> > I would suggest that the address correspond to the PSC lead.
> GRASS> g.version -c
> GRASS 6.3.cvs (2006)
> Copyright and License Statement
> The Geographic Resources Analysis and Support System (GRASS)
> Geographic Information System (GIS) is Copyright by the
> GRASS Development Team headquartered at ITC-irst, in Trento, Italy.
> This program is free software; you can redistribute it and/or modify it
> under the terms of the GNU General Public License as published by the
> Free Software Foundation; either version 2 of the License, or (at your
> option) any later version.
> Parts of GRASS are not copyright by the GRASS development team.
> The original authors hold the copyrights and you have to abide
> to their licensing terms where noted.
> (Keep in mind that code linking into GRASS can only be distributed
> if compatible with the GPL.)
> This program is distributed in the hope that it will be useful,
> but WITHOUT ANY WARRANTY; without even the implied warranty of
> MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
> GNU General Public License (GPL) for more details.
> You should have received a copy of the GNU General Public License
> along with this program; if not, write to the
>   Free Software Foundation, Inc.,
>   59 Temple Place - Suite 330,
>   Boston, MA  02111-1307, USA.
> Questions regarding GRASS GIS should be directed to the
> GRASS Development Team at the following address:
>  ITC-Irst
>  c/o M. Neteler
>  SSI/MPA
>  Via Sommarive, 18
>  38050 Trento (Povo)
>  Italy
>  neteler at itc.it
IMHO, this should be copied into documentation or at least referenced.
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
More information about the grass-psc mailing list
