[GRASS-PSC] SoC
Paolo Cavallini cavallini at faunalia.it
Mon Jul 30 04:07:58 EDT 2007
Why not putting the modules on the CVS? This way testing will be easier
and faster.
pc
Wolf Bergenheim ha scritto:
> On to the two projects:
> v.generalize:
> v.generalize is fully functional complete with manual and smoothing and
> simplification operations. The module works with both areas and lines.
> Attribute tables are also copied and cats are preserved. Please give the
> module a try and send us feedback!
> The rest of SoC will be spent in implementing other generalization
> operations and getting all the rest of the bugs out.
> v.path.obstacles:
> This module creates a visibility graph from non-intersecting lines and
> boundaries. It is actually remarkably fast. This output vector map can
> be used with graph analysis modules like v.net.path to find the shortest
> path between point A and B in free vector space. This project is in a
> testable shape. Not everything works perfectly yet, but Maximilian is
> actively working on it. We could use some feedback so if you are
> interested in this functionality, please try it out, and let us know
> what you think.
> Maximilian also brought up the issue that perhaps this module should be
> renamed to v.net.visibility. Any comments?
> --Wolf
Paolo Cavallini
http://www.faunalia.it/pc
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/grass-psc/attachments/20070730/f6dd575a/signature.bin
More information about the grass-psc mailing list
