R: [GRASS-PSC] SVN Write Access Request
    Hamish
    hamish_b at yahoo.com
    Sat May 17 19:51:40 EDT 2008
Marco:
> >> 2) branches/develbranch_6/win32
> >> the folder where i put all the scripts and files
> >> needed to prepare the release installer (as an exe file).
> >why refer to 32bit in the dirname?
> Good question; actually I named it as I'm used in my
> windows projects, because I build on a 32 system;
> BTW, I don't know if MSYS/MinGW + NSIS are available
> even for Win64...
> For me it's the same... We can call it just
> "Windows"
too generic- we use X-windows and rastr regions are call "windows" internally. why not just use the same as on the website: mswindows?
> >> Just few questions: all the files (dos batch scripts, the
> >> NSIS script, icons and documents) are made by me, with the
> >> exception of:
> >> 2.1) the bmp files (4) for the installer GUI,
> >> taken from the standard
> >> library of NSIS (that is OS, obviously)
> > it may be "open source", but that means 1001 different things, many
> > of which we can not touch. what is the license exactly? are
> > those 4 files distributed under terms compatible with the GPL?
> > If not GPL is it one of the OSI usual-suspects approved set?
> From the NSIS official web site:
> Applicable licenses
> * All NSIS source code, plug-ins, documentation, examples,
> header files and
> graphics, with the exception of the compression modules and
> where otherwise
> noted, are licensed under the zlib/libpng license.
> * The zlib compression module for NSIS is licensed under
> the zlib/libpng
> license.
> * The bzip2 compression module for NSIS is licensed under
> the bzip2 license.
> * The lzma compression module for NSIS is licensed under
> the Common Public
> License version 1.0.
> zlib/libpng license
> This software is provided 'as-is', without any
> express or implied warranty.
> In no event will the authors be held liable for any damages
> arising from the
> use of this software.
> Permission is granted to anyone to use this software for
> any purpose,
> including commercial applications, and to alter it and
> redistribute it
> freely, subject to the following restrictions:
> 1. The origin of this software must not be misrepresented;
> you must not
> claim that you wrote the original software. If you use this
> software in a
> product, an acknowledgment in the product documentation
> would be appreciated
> but is not required.
> 2. Altered source versions must be plainly marked as such,
> and must not be
> misrepresented as being the original software.
> 3. This notice may not be removed or altered from any
> source distribution.
> About the above mentioned terms:
> 1. done:
> http://grass.osgeo.org/grass63/binary/mswindows/native/#Install%20GRASS
> 2. I didn't altered the source, I'm using only the
> binaries
> 3. We are not distributing the source code
> >> 2.2) a small part of the installer, a function to let replace
> >> parts of strings; I just copied and pasted it, maintaining
> >> the header, where is clear the line ";Written by [author]"
> > what license terms did the author provide it with? you can not
> > just cut and paste things from the internet or "cook books",
> > even with attribution. is it a simple one-liner that is hard
> > to write any other way, or is it an original work?
> > without a clear license you can not distribute the code.
> I found it on the wiki/examples section of NSIS site
> http://nsis.sourceforge.net/StrRep
> Since it's an example it lays in the zlib/libpng
> license mentioned  above.
> In particular, as I didn't modified the code, it
> respects all the terms in it.
as "examples from website" is clearly put in the license statement,
it seems like no extra effort is required there.
Hamish
More information about the grass-psc
