[GRASS-PSC] svn addons access
    geonomica
    geonomica at gmail.com
    Fri Oct 10 02:54:16 EDT 2008
Hamish wrote:
> geonomica:
>> I've still troubles with svn addon access.
>> I can't comit my directory because with this command:
>> "svn commit -m "multi-criteria geographic tool" raster/mcda --username
>> gianluca --password  my_psw_osgeo"
>> I get this message:
>> "svn: Commit failed (details follow):
>> svn: MKACTIVITY of '/grass/!svn/act/a2cb3914-df45-48a4-83a0-458bc6519c4b':
>> 403 Forbidden
>> (https://svn.osgeo.org)"
>> My username and password are correct because I verified on
>> osgeo web page.
> did you do the initial checkout using http:// instead of https:// ?
> Can you try again from zero, creating a new directory then svn checkout,
> etc...?
> Hamish
I've tried from zero, with checkout with http:// instead https://. I've
added new directory and repeat commit command but ... all is the same.
If you thnk is usefull, I'll send my osge password.
Hy gianluca
More information about the grass-psc
