[GRASS-PSC] GRASS add-on sharing and write access
    Nagy Edmond
    nagy.edmond.eno at gmail.com
    Thu Dec 14 03:24:27 PST 2017
Dear GRASS-PSC,
Recently, I've been working with least-cost paths in GRASS, and to save up
time, I decided to automate the process by writing an add-on that generates
a vector output resembling a network from a set of input vector points. It
is mostly based on r.cost/r.walk and r.drain.
I would be happy to share it with the community, and include it into the
official repository. To build some trust, I considered uploading the py
script on GitHub for you to look at the code, but I wasn't sure if that
would be acceptable. I can still do it if there is no problem.
I have also read the RFC2 and accept the legal consequences. Unfortunately I
don't have a mentor, but I would appreciate if someone kindly suggested
someone. My "osgeo_id" is "eno91".
Thank you very much for your attention.
Best regards,
Nagy Edmond
Sent from: http://osgeo-org.1560.x6.nabble.com/GRASS-PSC-f4051248.html
More information about the grass-psc
