[GRASS-PSC] GRASS add-on sharing and write access
Anna Petrášová
kratochanna at gmail.com
Fri Dec 15 15:02:29 PST 2017
Hi Nagy,
On Dec 15, 2017 5:03 AM, "Nagy Edmond" <nagy.edmond.eno at gmail.com> wrote:
Dear All,
Thank you very much for your support.
The add-on is now on GitHub. https://github.com/NagyEdmond/v.lcp.network
Please feel free to evaluate it. Your feedback will be most welcome.
If I understand the code correctly, it computes always one way between 2
points, right? With r.walk the path could be different in each direction,
because of the walking coefficients - they are not symmetric for walking up
and downhill. So that's something which should be probably addressed,
either by computing paths in both directions, or documenting this
limitation in the manual.
Best,
Anna
All the best,
Nagy Edmond
Sent from: http://osgeo-org.1560.x6.nabble.com/GRASS-PSC-f4051248.html
grass-psc mailing list
grass-psc at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-psc
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20171215/fef8ffba/attachment.html>
More information about the grass-psc
