[GRASS-PSC] proposal: winGRASS 32bit versions - phasing out in 2020
Helmut Kudrnovsky
hellik at web.de
Thu Feb 25 13:17:14 PST 2021
Martin Landa wrote
> Hi,
> čt 25. 2. 2021 v 16:29 odesílatel Moritz Lennert
> mlennert at .worldonline
> > napsal:
>> Do I understand correctly that 32bit is already gone in the current
>> osgeo4w release ? Then yes, I think an announcement would be
> I don't think so, see
> http://download.osgeo.org/osgeo4w/x86/release/grass/grass/
>> appropriate. Otherwise, we could possibly combine it with the
>> announcement of a grass 8 release.
> I have no objection to drop 32bit support starting GRASS 8. It somehow
> corresponds with QGIS [1].
I suggest to drop it now that transition to 64bit only is clear.
citing Jürgen's mail
>It also has PDAL 2.2 which is required for native support of point clouds
in
>QGIS - something that you find lacking in the "old" OSGeo4W repository and
in
>turn in the current standalones.
maybe also a good time to switch to pdal powered modules in GRASS and drop
the liblas powered modules.
now to more challenging issues with a switch in short/mid/long term to the
new built OSGeo4W 64bit environment:
>Also note that it now only has one version of Python - namely 3.9, which
>doesn't support Windows 7 anymore.
are we already python 3.9 ready?
>Other updates include Qt 5.15, GDAL 3.2,
>PROJ 7.2 <=
just have a look at
http://download.osgeo.org/osgeo4w/testing/x86_64/release/proj/proj-data/
proj-data-1.4-1.tar.bz2 558M <= !!!
in PROJ7, there is a complete change how PROJ related/needed data is
handled:
(1) dynamically via https://cdn.proj.org/
(3) via a revamped proj-data with file size of more than 500 MB
* will GRASS be ready to handle it dynamically via CDN?
* including more than 500MB data into our standalone installer will explode
our used NSIS system, it won't work; maybe we have to switch also to a MSI
based system or another system
all in all, quite a lot of work will be needed to provide standalone/OSGeo4W
winGRASS.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/GRASS-PSC-f4051248.html
More information about the grass-psc
