[GRASS-PSC] GRASS DOI
Veronica Andreo veroandreo at gmail.com
Thu Jan 13 05:28:52 PST 2022
El jue, 13 ene 2022 a las 3:19, Vaclav Petras (<wenzeslaus at gmail.com>)
escribió:
> On Wed, Jan 12, 2022 at 4:40 PM Markus Neteler <neteler at osgeo.org> wrote:
>> FYI: GDAL started just today to generate a Zenodo entry. Even took the
>> top 16 commiters [3] according to GitHub and created a .zenodo.json
>> file to control authorship:
>> https://github.com/OSGeo/gdal/pull/5101/files
> .zenodo.json or CITATION.cff both should work now with Zenodo.
> CITATION.cff is new, but it works as far as I know. .zenodo.json allows you
> to set some Zenodo specific info. CITATION.cff is picked by other systems
> such as GitHub or FAIR systems. We could generate one from the other (that
> was recommended practice before Zenodo started to support CITATION.cff.
> In case we generate the file from the existing contributors.csv, we can
> generate both. Adding ORCiDs there would be nice.
+1 for adding ORCiD for those that have it
Is contributors.csv or starting a new list with the GitHub committers like
> what GDAL did more appropriate?
Maybe a new one is better. It will probably also depend if we want to list
all ppl in the contributors.csv or the main xx as in gdal.
Vero
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20220113/1ea0a1db/attachment.html>
More information about the grass-psc mailing list
