[GRASS-PSC] [Motion] Approve Linda's student grant final report and issue the second payment
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Mar 3 14:35:56 PST 2022
+1 (community vote)  Thanks Linda!
-jeff
On 2022-03-03 6:30 p.m., Veronica Andreo wrote:
> Dear PSC,
> Linda has just completed her project for the student grant and submitted
> the final report (I FWD it here in case you missed it).
> I hereby propose to approve her final report and issue the second half
> of the payment. Big thanks to Linda and her mentors for your work and
> commitment!
> I start with my +1 !!
> Vero
> ---------- Forwarded message ---------
> De: *Linda Kladivová* <L.Kladivova at seznam.cz <mailto:L.Kladivova at seznam.cz>>
> Date: mié, 2 mar 2022 a las 19:19
> Subject: [GRASS-dev] Final report for Mini project 2022: Redesigning a
> map display status bar combo box into a new settings dialog
> To: <grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>>,
> <grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>>
> Hello everyone,
> I am sending my final Mini Project report. The more detailed version
> with permanent links on GitHub PRs and with several screenshots can be
> found at the project wiki [1].
> *Abstract:*
> Especially for Single-Window GUI, the Map Display status bar needs to be
> lightened up a bit since in the case of opening more Map Display
> notebook pages the check box on the right side of the status bar gets
> shrunk. The solution is to remove the combo box in the status bar
> occupying too much space and implement a new Map Display settings dialog
> accessible from the top map display toolbar.
> *The state of the art BEFORE the start of Mini Project:*
> At this moment, the status bar at the bottom of the Map Display window
> consists of the text/widget section, the combo box, the mask and the
> check box. For the Single-Window GUI, the number of widgets must be
> reduced so that the check box on the right side of the status bar is not
> shrunk.
> *The state of the art AFTER ***Mini Project*:*
> The new Map Display settings dialog is introduced. The main task of this
> dialog is to manage General Map Display settings and Statusbar settings.
> It implies that the status bar combobox is not needed anymore because we
> can find all Map Display settings including status bar customization in
> the new dialog.
> *Next Steps:*
> Other possible improvements related to status bar stuff could be:
>   * Moving Projection page from GUI settings to the Map Display status
>     bar settings
>   * Adding context menu for status bar customization
>   * Adding EPSG code label of current location to the main status bar
>   * Merging „Go to coordinates X, Y“ and „Coordinates“ item into one widget
> Permanent links and screenshots can be found at [2] and [3].
> [1]
> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar
> <https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar>
> [2]
> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#FinalReport
> <https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#FinalReport>
> [3]
> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#BrandnewScreenshotsofMapDisplaySettingsdialog
> <https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#BrandnewScreenshotsofMapDisplaySettingsdialog>
> Have a nice week,
> Linda
> grass-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-dev
> <https://lists.osgeo.org/mailman/listinfo/grass-dev>
> grass-psc mailing list
> grass-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-psc
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the grass-psc mailing list
