[GRASS-PSC] [GRASS PSC elections 2024] Preliminary time table
Veronica Andreo veroandreo at gmail.com
Thu Sep 5 06:47:06 PDT 2024
Hi Hernan,
If it is ok with your timing, I'd prefer option 2.
When would you be sending out the announcement?
Vero
El jue, 5 sept 2024 a las 3:59, Hernán De Angelis via grass-psc (<
grass-psc at lists.osgeo.org>) escribió:
> All: What do you think of the following proposals:
> 1. we start on monday 9/9, using the current time table for everything
> else, thus making the nomination window one week longer and allowing it to
> overlap with the time given for changes to the vote register.
> 2. we start on monday 16/9, increasing the nomination period by a week
> (allowing a total of 3 weeks), moving all other dates one week later
> Hernán
> Den 2024-09-04 kl. 02:11, skrev Vaclav Petras via grass-psc:
> On Tue, 3 Sept 2024 at 19:25, Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> I thought in that way we give Hernan some more days to prepare
>> announcement and send out the instructions. But if he can send that ASAP,
>> it should be fine... In any case, we can send out reminders as well
> That's what I meant, but you said it better. If it starts sooner, it's
> better, but keeping the new timeline otherwise.
>> El mar., 3 sep. 2024 18:29, Vaclav Petras via grass-psc <
>> grass-psc at lists.osgeo.org> escribió:
>>> Is there any harm or difficulty in starting next week and making the
>>> nomination window wider?
> grass-psc mailing listgrass-psc at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/grass-psc
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20240905/48ca6cf7/attachment.htm>
More information about the grass-psc mailing list
