SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Sun Apr 2 11:11:49 EDT 2006
Hello giulio,
Threshold GRASS6 key metrics values at 2006-04-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 254 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/vector/v.in.dxf/add_arc.c functions
add_arc (Begins at: 9 Ends at: 100)
Complexity: | 23 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 92 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Brought to you by:
