SOCCER LAB GRASS QA: no clones 0 monsters and 0 warningsno clones 2 monsters and 0 warningsno clones 4 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sun Apr 2 11:11:49 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-02 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/vector/v.in.ascii/points.c functions
is_int (Begins at: 12 Ends at: 20)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
is_double (Begins at: 24 Ends at: 46)
Complexity:   |       6 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
points_analyse (Begins at: 48 Ends at: 185)
Complexity:   |      18 |     * |         |
ParamNBR:     |      11 |   *** | MONSTER |
CalledNBR:    |      39 |     * |         |
LOC:          |     138 |     * |         |
1 metric are OUT OF RANGE!
points_to_bin (Begins at: 187 Ends at: 300)
Complexity:   |      15 |       |      OK |
ParamNBR:     |      13 |   *** | MONSTER |
CalledNBR:    |      53 |     * |         |
LOC:          |     114 |     * |         |
Clone analysis:
Brought to you by:
