SOCCER LAB GRASS QA: 2 clones ( main.c main.c ) 10 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 14:39:17 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/vector/v.in.dxf/main.c functions
main (Begins at: 30 Ends at: 168)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      43 |     * |         |
LOC:          |     139 |     * |         |
metrics are OK
Clone analysis:
Brought to you by:
