SOCCER LAB GRASS QA: no clones 2 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 17:16:54 EDT 2006
Hello markus,
Threshold GRASS6 key metrics values at 2006-04-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 254 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/vector/v.select/main.c functions
add_aarea (Begins at: 26 Ends at: 54)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 29 | | OK |
metrics are OK
line_overlap_area (Begins at: 57 Ends at: 102)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 46 | | OK |
metrics are OK
main (Begins at: 105 Ends at: 486)
Complexity: | 34 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 115 | *** | MONSTER |
LOC: | 382 | *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Brought to you by:
