SOCCER LAB GRASS QA: no clones 4 monsters and 5 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 18:45:27 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 254 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/display/d.vect/label.c functions
label (Begins at: 10 Ends at: 154)
Complexity: | 24 | * | |
ParamNBR: | 6 | * | |
CalledNBR: | 34 | * | |
LOC: | 145 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Brought to you by:
