SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Apr 5 08:19:53 EDT 2006
Hello hamish,
Threshold GRASS6 key metrics values at 2006-04-05 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/lib/ogsf/gsd_img_ppm.c functions
GS_write_ppm (Begins at: 37 Ends at: 81)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
GS_write_zoom (Begins at: 83 Ends at: 127)
ParamNBR:     |       3 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
gsd_init_mpeg (Begins at: 134 Ends at: 232)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      99 |       |      OK |
metrics are OK
gsd_write_mpegframe (Begins at: 239 Ends at: 294)
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
gsd_close_mpeg (Begins at: 300 Ends at: 332)
LOC:          |      33 |       |      OK |
metrics are OK
Clone analysis:
Brought to you by:
