SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Apr 5 15:20:42 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 254 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/vector/v.in.dxf/add_text.c functions
add_text (Begins at: 8 Ends at: 146)
Complexity: | 32 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 139 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Brought to you by:
