SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Apr 5 17:05:47 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 254 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/vector/v.in.dxf/write_vect.c functions
write_vect (Begins at: 13 Ends at: 61)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 24 | | OK |
LOC: | 49 | | OK |
metrics are OK
write_done (Begins at: 63 Ends at: 109)
Complexity: | 6 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 47 | | OK |
metrics are OK
get_field_cat (Begins at: 111 Ends at: 200)
Complexity: | 13 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 28 | | OK |
LOC: | 90 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Brought to you by:
