SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Apr 5 17:48:45 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-05 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/display/d.vect/main.c functions
icon_files (Begins at: 35 Ends at: 81)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
test_bg_color (Begins at: 84 Ends at: 99)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
main (Begins at: 102 Ends at: 619)
Complexity:   |      71 |   *** | MONSTER |
CalledNBR:    |     174 |   *** | MONSTER |
LOC:          |     518 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Brought to you by:
