SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat Apr 8 06:39:50 EDT 2006
Hello soeren,
Threshold GRASS6 key metrics values at 2006-04-08 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/raster3d/base/r3.info.main.c functions
main (Begins at: 46 Ends at: 403)
Complexity:   |      44 |   *** | MONSTER |
CalledNBR:    |     184 |   *** | MONSTER |
LOC:          |     358 |   *** | MONSTER |
3 metric are OUT OF RANGE!
format_double (Begins at: 406 Ends at: 412)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Brought to you by:
