SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat Apr 8 21:09:42 EDT 2006
Hello cedric,
Threshold GRASS6 key metrics values at 2006-04-08 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/vector/v.extrude/main.c functions
main (Begins at: 37 Ends at: 343)
Complexity:   |      33 |    ** | Warning |
CalledNBR:    |     105 |   *** | MONSTER |
LOC:          |     307 |   *** | MONSTER |
2 metric are OUT OF RANGE!
extrude (Begins at: 349 Ends at: 434)
Complexity:   |       7 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      13 |       |      OK |
LOC:          |      86 |       |      OK |
1 metric are OUT OF RANGE!
Clone analysis:
Brought to you by:
