SOCCER LAB GRASS QA: 1 clones ( parser.c ) 2 monsters and 4 warnings
cvs at proxy.soccerlab.polymtl.ca
Sun Apr 16 17:10:55 EDT 2006
Hello cedric,
Threshold GRASS6 key metrics values at 2006-04-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/lib/gis/parser.c functions
G_disable_interactive (Begins at: 182 Ends at: 198)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_define_flag (Begins at: 201 Ends at: 249)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 49 | | OK |
metrics are OK
G_define_option (Begins at: 252 Ends at: 305)
LOC: | 54 | | OK |
metrics are OK
G_define_standard_option (Begins at: 308 Ends at: 430)
Complexity: | 16 | * | |
CalledNBR: | 16 | | OK |
LOC: | 123 | * | |
metrics are OK
G_define_module (Begins at: 433 Ends at: 467)
CalledNBR: | 1 | | OK |
LOC: | 35 | | OK |
metrics are OK
G_parser (Begins at: 469 Ends at: 727)
Complexity: | 34 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 56 | ** | Warning |
LOC: | 259 | *** | MONSTER |
1 metric are OUT OF RANGE!
G_usage (Begins at: 729 Ends at: 875)
Complexity: | 28 | ** | Warning |
CalledNBR: | 37 | * | |
LOC: | 147 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 877 Ends at: 893)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_usage_xml (Begins at: 895 Ends at: 1093)
Complexity: | 25 | * | |
CalledNBR: | 62 | ** | Warning |
LOC: | 199 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
G_usage_html (Begins at: 1095 Ends at: 1298)
Complexity: | 38 | *** | MONSTER |
CalledNBR: | 67 | ** | Warning |
LOC: | 204 | ** | Warning |
generate_tcl (Begins at: 1300 Ends at: 1371)
Complexity: | 9 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 72 | | OK |
metrics are OK
G_gui (Begins at: 1374 Ends at: 1396)
Complexity: | 5 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 23 | | OK |
metrics are OK
G_tcltk (Begins at: 1399 Ends at: 1414)
CalledNBR: | 2 | | OK |
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1416 Ends at: 1445)
Complexity: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 30 | | OK |
metrics are OK
show (Begins at: 1447 Ends at: 1460)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1462 Ends at: 1489)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 1494 Ends at: 1503)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 1505 Ends at: 1565)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 1567 Ends at: 1604)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 1606 Ends at: 1648)
Complexity: | 10 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 1650 Ends at: 1716)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 1718 Ends at: 1758)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 1760 Ends at: 1787)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 1789 Ends at: 1812)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 1814 Ends at: 1877)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 1879 Ends at: 1917)
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 1920 Ends at: 1977)
Complexity: | 11 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 58 | | OK |
metrics are OK
interactive (Begins at: 1979 Ends at: 2007)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2009 Ends at: 2017)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2019 Ends at: 2109)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
gis_prompt (Begins at: 2111 Ends at: 2177)
Complexity: | 14 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 67 | | OK |
metrics are OK
G_recreate_command (Begins at: 2179 Ends at: 2279)
CalledNBR: | 25 | | OK |
LOC: | 101 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
interactive_flag
Brought to you by:
