SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sun Apr 16 18:45:07 EDT 2006
Hello cedric,
Threshold GRASS6 key metrics values at 2006-04-16 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/display/d.mapgraph/main.c functions
main (Begins at: 17 Ends at: 154)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      37 |     * |         |
LOC:          |     138 |     * |         |
metrics are OK
Clone analysis:
Brought to you by:
