SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Mon Apr 17 18:07:31 EDT 2006
Hello cedric,
Threshold GRASS6 key metrics values at 2006-04-17 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/lib/display/tran_colr.c functions
D_translate_color (Begins at: 23 Ends at: 49)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
D_translate_or_add_color (Begins at: 51 Ends at: 90)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
Clone analysis:
Brought to you by:
