SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Mon Apr 17 18:14:26 EDT 2006
Hello cedric,
Threshold GRASS6 key metrics values at 2006-04-17 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/display/drivers/PNG/Color_table.c functions
set_color (Begins at: 12 Ends at: 18)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
PNG_reset_color (Begins at: 20 Ends at: 35)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
init_colors_rgb (Begins at: 37 Ends at: 40)
ParamNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
init_colors_indexed (Begins at: 42 Ends at: 83)
LOC: | 42 | | OK |
metrics are OK
init_color_table (Begins at: 85 Ends at: 99)
Complexity: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 15 | | OK |
metrics are OK
PNG_Color_table_float (Begins at: 101 Ends at: 122)
LOC: | 22 | | OK |
metrics are OK
PNG_Color_table_fixed (Begins at: 124 Ends at: 137)
CalledNBR: | 2 | | OK |
LOC: | 14 | | OK |
metrics are OK
get_color_rgb (Begins at: 139 Ends at: 142)
ParamNBR: | 3 | | OK |
LOC: | 4 | | OK |
metrics are OK
get_color_indexed (Begins at: 144 Ends at: 150)
LOC: | 7 | | OK |
metrics are OK
PNG_lookup_color (Begins at: 152 Ends at: 157)
LOC: | 6 | | OK |
metrics are OK
PNG_get_table_type (Begins at: 159 Ends at: 162)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Brought to you by:
