SOCCER LAB GRASS QA: no clones 0 monsters and 3 warnings
cvs at proxy.soccerlab.polymtl.ca
Mon Apr 17 19:56:45 EDT 2006
Hello hamish,
Threshold GRASS6 key metrics values at 2006-04-17 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/lib/segment/format.c functions
segment_format (Begins at: 41 Ends at: 44)
Complexity: | 1 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
at least 1 values are close to an outlier please consider revising code
segment_format_nofill (Begins at: 46 Ends at: 50)
LOC: | 5 | | OK |
_segment_format (Begins at: 52 Ends at: 101)
Complexity: | 7 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 11 | | OK |
LOC: | 50 | | OK |
write_int (Begins at: 103 Ends at: 113)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 11 | | OK |
metrics are OK
zero_fill (Begins at: 115 Ends at: 160)
Complexity: | 3 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 46 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Brought to you by:
