SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Apr 18 04:23:31 EDT 2006
Hello hamish,
Threshold GRASS6 key metrics values at 2006-04-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/vector/v.label/main.c functions
main (Begins at: 34 Ends at: 373)
Complexity: | 36 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 114 | *** | MONSTER |
LOC: | 340 | *** | MONSTER |
3 metric are OUT OF RANGE!
print_label (Begins at: 375 Ends at: 397)
Complexity: | 3 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 17 | | OK |
LOC: | 23 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Brought to you by:
