SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 18 11:03:55 EDT 2006
Hello glynn,
Threshold GRASS6 key metrics values at 2006-04-18 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/display/drivers/PNG/Color_table.c functions
set_color (Begins at: 12 Ends at: 18)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
PNG_reset_color (Begins at: 20 Ends at: 35)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
init_colors_rgb (Begins at: 37 Ends at: 40)
ParamNBR:     |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
init_colors_indexed (Begins at: 42 Ends at: 83)
LOC:          |      42 |       |      OK |
metrics are OK
init_color_table (Begins at: 85 Ends at: 101)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
PNG_Color_table_float (Begins at: 103 Ends at: 124)
LOC:          |      22 |       |      OK |
metrics are OK
PNG_Color_table_fixed (Begins at: 126 Ends at: 141)
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
get_color_rgb (Begins at: 143 Ends at: 146)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
get_color_indexed (Begins at: 148 Ends at: 154)
LOC:          |       7 |       |      OK |
metrics are OK
PNG_lookup_color (Begins at: 156 Ends at: 161)
LOC:          |       6 |       |      OK |
metrics are OK
PNG_get_table_type (Begins at: 163 Ends at: 166)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Brought to you by:
