[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat Apr 22 03:28:00 EDT 2006
Hello hamish,
ANALYSIS
lib/gis/error.c functions
G_message (Begins at: 81 Ends at: 91)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
G_fatal_error (Begins at: 93 Ends at: 107)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
G_warning (Begins at: 109 Ends at: 122)
LOC:          |      14 |       |      OK |
metrics are OK
G_suppress_warnings (Begins at: 124 Ends at: 131)
CalledNBR:    |       0 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
G_sleep_on_error (Begins at: 133 Ends at: 140)
LOC:          |       8 |       |      OK |
metrics are OK
G_set_error_routine (Begins at: 142 Ends at: 146)
LOC:          |       5 |       |      OK |
metrics are OK
G_unset_error_routine (Begins at: 148 Ends at: 153)
ParamNBR:     |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
print_error (Begins at: 156 Ends at: 206)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
log_error (Begins at: 208 Ends at: 243)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
write_error (Begins at: 245 Ends at: 274)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      14 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
mail_msg (Begins at: 276 Ends at: 294)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
print_word (Begins at: 297 Ends at: 347)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
print_sentence (Begins at: 350 Ends at: 386)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
G_info_format (Begins at: 388 Ends at: 403)
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-04-22 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
