[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Sun Apr 23 03:27:39 EDT 2006
Hello hamish,
ANALYSIS
display/d.graph/do_graph.c functions
set_graph_stuff (Begins at: 22 Ends at: 30)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 9 | | OK |
metrics are OK
set_text_size (Begins at: 32 Ends at: 44)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 13 | | OK |
metrics are OK
do_draw (Begins at: 46 Ends at: 72)
Complexity: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 27 | | OK |
metrics are OK
do_move (Begins at: 74 Ends at: 92)
LOC: | 19 | | OK |
metrics are OK
do_color (Begins at: 94 Ends at: 119)
Complexity: | 5 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 26 | | OK |
metrics are OK
do_linewidth (Begins at: 121 Ends at: 134)
CalledNBR: | 5 | | OK |
LOC: | 14 | | OK |
metrics are OK
do_poly (Begins at: 137 Ends at: 194)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 58 | | OK |
metrics are OK
do_size (Begins at: 196 Ends at: 222)
LOC: | 27 | | OK |
metrics are OK
do_text_rotate (Begins at: 224 Ends at: 237)
LOC: | 14 | | OK |
metrics are OK
do_text (Begins at: 239 Ends at: 250)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 12 | | OK |
metrics are OK
check_alloc (Begins at: 252 Ends at: 285)
CalledNBR: | 4 | | OK |
LOC: | 34 | | OK |
metrics are OK
do_icon (Begins at: 287 Ends at: 337)
CalledNBR: | 18 | | OK |
LOC: | 51 | | OK |
metrics are OK
do_symbol (Begins at: 339 Ends at: 396)
CalledNBR: | 6 | | OK |
LOC: | 58 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-04-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
