[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Apr 26 03:40:53 EDT 2006
Hello brad,
ANALYSIS
raster/r.watershed/seg/sg_factor.c functions
sg_factor (Begins at: 7 Ends at: 42)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 36 | | OK |
metrics are OK
len_slp_equ (Begins at: 45 Ends at: 64)
Complexity: | 3 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 4 | | OK |
LOC: | 20 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-04-26 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 255 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
