[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Apr 26 03:40:53 EDT 2006
Hello hamish,
ANALYSIS
db/base/execute.c functions
main (Begins at: 27 Ends at: 81)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 55 | | OK |
metrics are OK
parse_command_line (Begins at: 83 Ends at: 133)
Complexity: | 4 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 51 | | OK |
metrics are OK
get_stmt (Begins at: 136 Ends at: 162)
CalledNBR: | 8 | | OK |
LOC: | 27 | | OK |
metrics are OK
stmt_is_empty (Begins at: 165 Ends at: 170)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-04-26 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 255 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
