[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Apr 26 15:45:24 EDT 2006
Hello markus,
ANALYSIS
raster/r.random/main.c functions
main (Begins at: 12 Ends at: 184)
Complexity:   |      18 |     * |         |
CalledNBR:    |      53 |     * |         |
LOC:          |     173 |     * |         |
metrics are OK
has_percent (Begins at: 186 Ends at: 192)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
do_info_exit (Begins at: 195 Ends at: 204)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-04-26 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     255 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
