[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/lib/pad.c |8
clones ( clip.c Color.c command.c connect_sock.c Erase.c
Get_t_box.c pad.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Aug 1 18:10:48 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/lib/pad.c functions
free_item (Begins at: 11 Ends at: 27)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 17 | | OK |
metrics are OK
new_item (Begins at: 29 Ends at: 51)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 23 | | OK |
metrics are OK
remove_value (Begins at: 53 Ends at: 72)
LOC: | 20 | | OK |
metrics are OK
append_item (Begins at: 74 Ends at: 116)
Complexity: | 8 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 43 | | OK |
metrics are OK
delete_item (Begins at: 118 Ends at: 138)
CalledNBR: | 2 | | OK |
LOC: | 21 | | OK |
metrics are OK
find_item (Begins at: 140 Ends at: 149)
CalledNBR: | 1 | | OK |
LOC: | 10 | | OK |
metrics are OK
pad_list (Begins at: 151 Ends at: 154)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
delink_pad (Begins at: 156 Ends at: 170)
LOC: | 15 | | OK |
metrics are OK
create_pad (Begins at: 172 Ends at: 192)
LOC: | 21 | | OK |
metrics are OK
delete_pad (Begins at: 194 Ends at: 212)
Complexity: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
find_pad (Begins at: 214 Ends at: 222)
LOC: | 9 | | OK |
metrics are OK
invent_pad (Begins at: 224 Ends at: 233)
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file has 8 potentially cloned functions:
remove_value append_item create_pad delink_pad delete_pad delete_item find_item new_item
In display/drivers/lib/pad.c clones of delink_pad are:
lib/driver/pad.c delink_pad
In display/drivers/lib/pad.c clones of append_item are:
lib/driver/pad.c append_item
In display/drivers/lib/pad.c clones of new_item are:
lib/driver/pad.c new_item
In display/drivers/lib/pad.c clones of create_pad are:
lib/driver/pad.c create_pad
In display/drivers/lib/pad.c clones of delete_pad are:
lib/driver/pad.c delete_pad
In display/drivers/lib/pad.c clones of find_item are:
lib/driver/pad.c find_item
In display/drivers/lib/pad.c clones of remove_value are:
lib/driver/pad.c remove_value
In display/drivers/lib/pad.c clones of delete_item are:
lib/driver/pad.c delete_item
Threshold GRASS6 key metrics values at 2006-08-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
