[GRASS-QA] GRASS QA: glynn |
./grass6/display/drivers/lib/connect_sock.c |3 clones (
clip.c Color.c command.c connect_sock.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Aug 1 18:10:48 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/lib/connect_sock.c functions
get_connection_sock (Begins at: 18 Ends at: 55)
Complexity: | 7 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 23 | | OK |
LOC: | 38 | | OK |
metrics are OK
prepare_connection_sock (Begins at: 58 Ends at: 76)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 19 | | OK |
metrics are OK
check_connection (Begins at: 79 Ends at: 100)
Complexity: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 22 | | OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
prepare_connection_sock check_connection get_connection_sock
In display/drivers/lib/connect_sock.c clones of get_connection_sock are:
lib/driver/connect_sock.c get_connection_sock
In display/drivers/lib/connect_sock.c clones of check_connection are:
lib/driver/connect_sock.c check_connection
In display/drivers/lib/connect_sock.c clones of prepare_connection_sock are:
lib/driver/connect_sock.c prepare_connection_sock
Threshold GRASS6 key metrics values at 2006-08-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
