[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/lib/Respond.c
|no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Aug 1 18:10:48 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/lib/Respond.c functions
COM_Respond (Begins at: 5 Ends at: 9)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
