[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/lib/text3.c |no clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Aug 1 18:16:04 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/lib/text3.c functions
draw_main (Begins at: 42 Ends at: 257)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |     216 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
soft_text_freetype (Begins at: 259 Ends at: 267)
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
soft_text_ext_freetype (Begins at: 269 Ends at: 289)
LOC:          |      21 |       |      OK |
metrics are OK
get_text_ext_freetype (Begins at: 291 Ends at: 297)
ParamNBR:     |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
