[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/lib/Color.c |1 clones ( Color.c Color.c Color.c Color.c Color.c Color.c Color.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Aug 1 18:16:03 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/lib/Color.c functions
DRV_lookup_color (Begins at: 10 Ends at: 15)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
DRV_color (Begins at: 17 Ends at: 21)
ParamNBR:     |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
COM_Color (Begins at: 23 Ends at: 26)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
COM_Color_RGB (Begins at: 28 Ends at: 32)
LOC:          |       5 |       |      OK |
metrics are OK
COM_Standard_color (Begins at: 34 Ends at: 40)
CalledNBR:    |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
COM_Color_offset (Begins at: 42 Ends at: 45)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
LIB_get_color_index (Begins at: 47 Ends at: 73)
Complexity:   |       5 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
LIB_get_color_index_array (Begins at: 75 Ends at: 109)
LOC:          |      35 |       |      OK |
metrics are OK
get_color_offset (Begins at: 111 Ends at: 114)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In display/drivers/lib/Color.c clones of  LIB_get_color_index_array are:
	lib/driver/Color.c  LIB_get_color_index_array
Threshold GRASS6 key metrics values at 2006-08-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
