[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.carve/enforce_ds.c |no clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu Aug 3 07:51:57 EDT 2006
Hello brad,
ANALYSIS
raster/r.carve/enforce_ds.c functions
enforce_downstream (Begins at: 37 Ends at: 76)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
process_line (Begins at: 79 Ends at: 191)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |     113 |     * |         |
metrics are OK
clear_bitmap (Begins at: 194 Ends at: 201)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
traverse_line_flat (Begins at: 204 Ends at: 227)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
traverse_line_noflat (Begins at: 230 Ends at: 254)
ParamNBR:     |       4 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
set_min_point (Begins at: 258 Ends at: 284)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       9 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
lowest_cell_near_point (Begins at: 288 Ends at: 405)
Complexity:   |      25 |     * |         |
CalledNBR:    |      22 |       |      OK |
LOC:          |     118 |     * |         |
metrics are OK
process_line_segment (Begins at: 413 Ends at: 503)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      91 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-03 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
